slot port question
I just realized that the attachment uploader resized the image and it's really hard to read so here's everything from that shot in plain text:
Width: 28
Height: 12
Depth: 15.5
Thickness: .75
Port width: 1.5
Port height: 10.5 (-1.5 from thickness)
Vb: 2.25 ft^3
Fb: 35hz
Port Length: 12.09
I've read that it's best not to exceed a ratio of 9:1 for the port. Does this mean the port's width in respect to the box width? The WxH of the port? I came across people talking about both and I'm confused.. WxH of the port comes to about 7:1 whereas portW x BoxW comes out ~15:1. I just want to be sure before I make another box that I'm unsatisfied with. I am open to altering what I have now, all the dimensions can give or take a couple inches with the exception of the depth, 15.5 is as deep as I can go.
Width: 28
Height: 12
Depth: 15.5
Thickness: .75
Port width: 1.5
Vb: 2.25 ft^3
Fb: 35hz
Port Length: 12.09
You are correct that that is in fact a 7:1 ratio. BUT, that isonly 15.75 inches squared of cross sectional area, depending on how much power, and what sub, you may encounter port noise. This is where using aprogram like WinISD pays off as you can get an idea of the port velocity. This is where some ball park numbers come from, I find that generally 12-16 square inches of port cross sectional area per cubic foot of volume are a good starting point.
Thanks for your help! Unfortunately I don't have windows so that program is out of the question for me.
For about a month or two longer I will be running a Solo Classic 12 @ about 600rms (MRX-M110). Still deciding between a CVX, W6, re s-ex, TypeX, or maybe a few others. I'm now considering an L port to tune a little lower.
Here's what I have now:
Width: 28
Height: 13.5
Depth: 15.5
Thickness: .75
Port width: 2
Port height: 12
Vb: 2.24 ft^3
Fb: 32hz
Port Length: 12.75
Port Length2: 7
Port Area: 24
Does this look better?
Edit: I couldn't find information on subwoofer placement in the box.. With an L port, do I want it to be closer to the port? Because the L part of the port is only 7", would this be a bad Idea and I should place the sub on the opposite end? Dead Center?
bump
Anyone else with input? I got a sheet of MDF and will be pulling the trigger sometime this weekend. Leaning more towards the L port.
bombsaway
bombsaway
Yup
bombsaway
