sketchup pros---help please
To make volume a sinch...just use the line tool and draw a line acrossed the opening into the port so you can highlight just the airspace portion of the enclosure (basically take the line tool and outline the area you want to calculate) and right click, go to info on the section and it'll tell you how many sq feet of area it is and then simply devide the height (in inches) by 12 to get feet and multiply the two to get your airspace for the space //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thank you sir! It's looking like I might shy away from 4-12s though because I can't bring myself to give up all the bed space since I use the bed all the time. I drew up a new design for 2-12s that is 5'' wider than the box I have now and the same depth. It is 5@33. The only reason why I want to switch setups is because I plan to get a bigger amp in the future and I know the LV4s can't handle any more power. I'm thinking of going with either LV4XLs, AA Havocs, BTLs, or something else that will kill the lows and handle 2k or more daily.
KHARPS
KHARPS
IL
dappa5
NorthFramingham
    Jun 30, 2026
