sketchup help
thank you
if you right click in mspaint, and go to 'stretch/skew' you can make it bigger or smaller, but it will be blurry. so the only real way to make it bigger is to have it bigger in the first place
YOU ARE AN IDIOT //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
only thing right you have said would be pointing him in the right direction on uploading and posting using photobucket.
op here is what you do bro.....
in sketchup there is this nifty little tool called "export 2d graphic". what that does is export whatever view you currently have on sketchup to a jpeg file. then upload and post.
do this
File>export>2d graphic
/thread
^^^^^^^^YOU ARE AN IDIOT //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
do this
/thread
i just told him how i do it, i didnt say its the only way.
also, its ironic that you call me the idiot, when you just answered a question that he wasnt even asking.
if he did it the way i said he wouldn't have to re-size the image. actually would have to reduce the image
still cant make bigger openable?
It's small because photobucket automatically resizes it. Before you select the file to upload, look at the little area below it. There should be some options as to what size you'd like it to be. Then go into your album in photobucket. If you run your mouse over the picture you want, photobucket already puts the special HTML code to post pictures onto forums. Just find the code that says IMG, copy, and paste that link into a thread or your signature and you're golden.
Good luck //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
dappa5
DO WORK! (if u can)
dappa5
S.W.FL
dappa5
