Skar vvx 15 v2 dual 2 ohm fs
82cutty
Haven't been on here in a while . My old log in doesn't work so I registered again . Anyway wondering if anyone actually knows what the FS of this woofer is . Manual says 21hz...website says 39.5 hz . Doing a single 15 4th order bandpass in my ex. cab s-10 . Trying to crunch up some numbers for the box . Thanks
Yeah 21hz. is pretty low . Maybe Ill give them a call tomorrow and see if I can get an answer . The vas is also different on the website compared to the manual .
652
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
940
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
82cutty
82cutty
Buffalo N.Y.
82cutty
    May 16, 2024
    May 16, 2024
