Skar vvx 15 v2 dual 2 ohm fs
82cutty
Haven't been on here in a while . My old log in doesn't work so I registered again . Anyway wondering if anyone actually knows what the FS of this woofer is . Manual says 21hz...website says 39.5 hz . Doing a single 15 4th order bandpass in my ex. cab s-10 . Trying to crunch up some numbers for the box . Thanks
Yeah 21hz. is pretty low . Maybe Ill give them a call tomorrow and see if I can get an answer . The vas is also different on the website compared to the manual .
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
147
725
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
959
82cutty
82cutty
Buffalo N.Y.
82cutty
audiobaun
    May 19, 2024
    May 19, 2024
