Skar going into protective mode
Can you not get a adjustable regulator? I know in my jeep the CPU controlled what my alt would charge at so I had to get an external an bypass it or is that what you already had? I might have missed it.
I looked into it but it's not recommended for me they said .
Page 5-31 of 2011 owner's manual:
The normal battery voltage range
is 11.5 to 15.5 volts. You can monitor
battery voltage on the DIC by
pressing the vehicle information
button until Battery Voltage is
displayed.
Also from GM service information: 90% duty cycle of alternator will result in 15.5 volt output. 10% = 11volts. This is controlled by the ECM.
I received a skar rp 2000.1 on 12/29 played fine for a week starting last week amp had been going into protective mode, manual recommends 0 gauge and 200 amp fuse, I have 4 gauge and 150amp breaker, breaker hasn't tripped once, car must turn off then back on to go back to power, amp wired to one ohm. Is the small 4 gauge and breaker causing this?
Most problems is the rcas your using, try using a different amp to test, my 2 Skar 1500 watt rms would start up with a red light to indicate that something is wrong then would go blue like it’s ready for music. But no sound. So I hooked up my old amp and no sound, easy fix RCAs were fried. Easy fix.
6 year old thread..
SLAB153
SLAB153
Lafayette, LA
Grimmjoww
