Single Xfl on an AB ph4000?
Lowlacs
I have a solox now on an AmericanBass Phantom4000(2Krms?) but just cannot give it the enclosure it needs considering im in a single cab super duty now. Ive ran this amp on a pair of the xfls but Id swear they were begging for more. So Im now considerin giving a single xfl dual2 3cubes and all of the ph amp. Im on a short budget, due to the season, so please no (other)amp suggestions as this is what I have and can afford.
So do u guys think the Phantom amp will supply clean enough signal to overpower the Xfl sub without issues? Also do u think the Xfl can take it? Id hate to launch or burn a coil. I have a Deka g31 going in 2ft from the amp along with an interstate Megatron under the hood so I dont think power supply will be a problem. Also will be using a dmm to set gain until I can find a DD1 or an Oscope. I suppose I could always gain down if need be but....
2k your reaching to the top but as long your not a idiot on the volume knob you'd be great.....
Well, My drinkin days are over so I dont have nearly as many idiot moments anymore. So gain Down abit and with some common sense this should be a decent combo.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
411
673
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
884
Lowlacs
Lowlacs
Live Oak Fl. 32060
Lowlacs
Brendon Jenness
    May 8, 2024
    May 8, 2024
