Single E8 isn't quite enough . . .
bcramsey
OK, I have an E8 in a sealed .3cf box getting about 300 watts bridged from a 2ch amp. I also have 6.5 components and 4x6's getting about 50 watts each from a 4 ch amp. I listen to primarily rock and alternative music. The sub sounds better on high volume but I'm looking for a little more. However the sub sounds great on bass heavy tracks and rap at all volume ranges. I want good sound quality and like the E8 but wanting more. All of this is in a 2000 Gmc sierra ext cab.
Questions
1. Would I benefit much from a small ported box
2. Would I be better off just getting a 10" sub in a small sealed box?
3. What 10" sub 4ohm getting 300 watts would you recommend? RE 10, Infinity Perfect 10, or other suggestions???
Thanks for the quick replies. I will look into building a ported box around .6cf per spec. I just haven't seen many small ported boxes before. This will be my first ported box build.
Ported boxes are extremely easy as long as u follow the plan/design to a T.
A single RE SR off that wattage would be pretty decent. But try this small ported box first and see how that works for ya.
bcramsey
bcramsey
Elgin, IL
CobraStang98
vegang
vegang
