Single 15" Info in post!!!
disturbed471985
Rating: 94.4%
17 1 0
Looking for a 15 that can wrk well in a 4.25cf box that before sub displacement. Box i tuned to 30hz but I can just swap aeros's and change the tuning. Ok sub must be able to take a min of 2.5K daily. Needing coil options that would allow me to wire down to .5ohm .67ohm min.... Budget well depends on what u got. This is for a daily setup so no pure burp subs.... Sub and port will both be in a semi wall firing into the cab blocking them off from the trunk...
Used every size but a 15 and I wanna give it a shot.....
http://www.caraudio.com/forums/subwoofer-classifieds/551876-15-shocker-singature-series-d1-4-copper-coil-very-stiff-suspension-x4.html
Could do one with a beat-up dustcap area for 395 shipped. Can recone or send you recone parts for a little more. Work good in 4 cube, I like high 30's to 40hz tuning... mechanically won't have a problem with 5K as they are. Thermally you'll run into limits on any coil with 2500 depending how you use it. You'd have plenty of time to smell it and turn it down before failure though.
Rd heavyweight d1
disturbed471985
disturbed471985
Greenwood, La
RangerDangerV2
