Single 10" w6 ported box dimensions????
Or if you want a truly flat response out of your subwoofer, WinISD recommends 2.9 cubic feet tuned to 21.63 Hz. I have found that JL Audio's recommendations tend to **** royally, but maybe that is just me...
2.9 for a single 10?//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Honestly...
JL has ridiculous recommended dimensions.
The w0's slot was 1" wide and like 14" high or something... obviously pisses all over the 9:1> ratio I like to keep when I design boxes.
The possibility of port noise with a port smaller than 2" is just great. But it all depends on the driver, I suppose.
The JL recommendations make a couple assumptions that may or may not be valid depending on the user. One assumption is that the system will be used to play music at reasonable volumes. Lower realized power means that you can get away with a much smaller port without having an issue with noise.
dutchbroracing
dutchbroracing
San Luis Obispo
helotaxi
