Single 10 and Single 12?
gabrielpanoussi
After toying with the idea of 2 10's vs 1 12 I thought has anyone done one 10 and one 12?
I came across a deal on some subs I bought 2 10's and 2 12's. I also prefer to use sealed enclosures.
So say a sealed stand alone SVC10 and a sealed stand alone SVC12 on a single class a/b mono block amp at 2 ohm? The subs and amps are Boss specifically Boss Cxx10 and Cxx12 the amp is A Boss Audio AR2000M. And yes I plan on turning the gain on the amp down hopefully.
I have.. i ran asingle 12 in rear substage @32 htz on an XFL 12, and up front I ran a Pair of Dayton 80 rms 10s @45 htz under the front seats
yeah stick with the 10's and so u know that amp only does 400 rms.. the 4k tested at 900..
ouch! was that @4ohm?
yep like he said they do between 10-20% rated power.. for $200 u can get a 30 pound cab 1600 amp that does over 1600 at 1 ohm.. or my tiny ppi p1k tested over 1100rms $169 very dependable or twisted sound 1k (probably does 1200 or so) $219 several good amps under $250..
Why you say 30 lb old man?.. you don't know (like a lot of other things BTW) ... I told you BEFORE it's less than 15lb... sheesh... always the expert and tryin to change the thread into a conversation about your sh*t... your h/u amplified single 12 system is nothing to emulate... lol
Bad info again!
n
Bad info again!
Gramps flappin his gums about something he's never seen or used? Never! //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
n
i ordered cab for friend have seen heard and held it.. i know it's heavy but i didn't weigh it and not my fault cab shows 30 pounds
I remember now... wasn't that the "smoking cab"... I forget as there have been SO many colorful stories... we should try to list them all... what a thread!
yes it was and it still works he don't know what happened except some light on the amp don't work now or something., he's 30 miles away so don't see him much..
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
611
911
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
gabrielpanoussi
gabrielpanoussi
Flint, MI
gabrielpanoussi
    May 31, 2024
    May 24, 2024
