simple tuning question.........
Specify what frequency range.
too low as in what freq?
upper bass as in what freq?
saY LIKE YOU TUNED down to 12 - 13Hz. what would happen?? would anything happen to the bass between 45 - 70Hz?? do you have to make a massive box for that low of a tuning??
Assuming your woofer allows good performance tuned low and across the midbass
region then nothing happens to the 45hz - 70hz region. But when you play both tones at
the same time you may have SQ issues. You may have some form of
modulation distortion. But this happens to any subwoofer system playing
two notes at the same time where the frequency different is alot.
For example, lets say you played a 20hz sine wave then feed the woofer
some midrange frequencies, perhaps someone talking. The voice will be
modulation akin to you talking into a spinning fan blade. The voice is modulated,
sorta like a stobe light effect. When the cone has to move alot, higher excursion,
it can't do 'delicate' [lower excursion] upper frequencies when it's trying to do both.
The best bass subsystem is really a two or three part design. One woofer
to play upper bass, one woofer to play lower bass and the crazy woofer
to do 10hz - 20hz. When you split the job amongst two or three woofers you
lessen the effects of modulation, big boost to SQ.
Assuming your woofer allows good performance tuned low and across the midbassregion then nothing happens to the 45hz - 70hz region. But when you play both tones at
thanks thy, but i'm talking strictly HT subs, not left and right front speakers
Most people that make HT subs tuned low, ie 15-17hz are happy with justthat. They may cross it over at 70-80hz, no higher.
If you want something more elite, you split the HT sub into two systems.
The 10hz system and the system that handles the higher bass.
It's esoteric.
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif
That's be my ideal.
adio
THE STEREOTYPE FIGHTER!!!
adio
college park, ga
adio
