Simple Question?
Which would be better?
1200watt amp pushing two 12'' subwoofers max peak 1600watt
1200watt amp pushing two 10'' subwoofers max peak 1200watt
Thnx..
what are the RMS ratings of both the amps and subs? peak watts are a stupid marketing scheme
10s : 300W RMS Power Handling Per Sub
600W RMS Power Handling Per Pair!
12s : 400W RMS Power Handling Per Sub
800W RMS Power Handling Per Pair!
Amp : 1200W Max Power
300W x 2 RMS @ 4Ω
450W x 2 RMS @ 2Ω
600W x 1 RMS @ 4Ω
Either one would work fine. You wouldn't notice an audible difference between having 600w and 800w on the 12's.....
But it sort of depends on the amp. If that's a "600w RMS" amp that really only outputs 400w............
Also assumes you can obtain a 4ohm mono load with both subs.
Danny52186
Danny52186
Tennessee
bikejunkie223
michigan born
    May 14, 2026
michigan born
    May 14, 2026
