Silly question
BassAddictJ
well im gonna be upgrading to 4 runs of 1/0, 2 pos, 2 neg. curently i have 2 runs. well i noticed one of u current runs is just 0awg and not 1/0awg. I doubt itd make a differance, but i wanted to double check. should i make sure all 4 runs are 1/0 or (making the most sense) will it not really matter?
Or his chassis is a bad conductor (multiple weld points).
chasis is a good ground unless you're moving a shit ton of current.
im gonna be moving a shit ton of current //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
**** wasting that much wire.
I grinded done a section on my frame and did triple frame grounds in the front... and then triple frame grounds on the same frame in the rear. Then coated them in underbody coat after torque-ing them down with lock washers.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nG
I'm assuming you would be moving a lot of current due to the fact you're using 0/1 awg.
We are agreeing.
BassAddictJ
BassAddictJ
FL
ngsm13
vegang
vegang
