should i run 4 or 0?
audiobahnuser18
Hey guy's right now im running 4awg wire and a anl fuse but im gonna do the big 3 soon but was wondering should i switch out to 0awg wire or just run 4 awg also for the big 3 if i was going to switch out to 0 awg would be for everything the system and they big 3 what you guy's think? im running 2 pioneer tsw306sDVC 12's running 800to each with a digital audio monoblock amp.
Might as well run 0guage. Nothing bad could really come of it. if you're doing to big three you might as well. dont see a point on why you shouldnt
Yeah that's what i was thinking myself thanks for the info tex. do got one question though with my negative batter cable it actually has to wires coming to it one to the terminal one to the body's chasis but how would i go about that if im switching out the negative cause your switching out both the positive and negative stock wires that go to those terminal's right? sry if this is confusing i read the sticky on the big 3 but im still kinda lost but i get most of it.
Alright guy's i just remember i can probably get wire cheap from my old custom job:)//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. he uses stinger i mean i've used other stinger product's but never there wire what do you guy's think of it or should i run tsunami???
Also using 0 gauge means you're ready for the next upgrade.
The 2 smaller factory grounds can be added to the new battery terminal you'll use for the 0 gauge. Just cut them off the old terminal and attach with ring terminals.
stinger is fine, or tsunami, whichever is cheaper. check out knukonceptz.com if you can't find anything cheap
audiobahnuser18
audiobahnuser18
Mi
audiobahnuser18
