Shortage in speakers.
  • 4
jg77
25
Florida
I have had my aftermarket stereo and door speakers for a couple of months and haven't had any problems until now. I was moving some stuff today and put some stuff in my trunk and my speakers started going in and out. Their is wiring in my trunk but I'm not sure what is to. All my speakers have static and aren't playing. They do play for a little bit if I go around a curve or something. I'm not sure if I messed up something in the trunk or if the something else is the problem. Any help is appreciated. Thanks.
check to see that you didnt pull any wires out of the amp one could be out and when you turn it hits the terminal and closes the loop... i would definately look into it all very closely your power wire may be loose and this could cause serious issues if you dont have it properly fused
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
182
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
95
38
327
jg77
jg77
Florida
rosshimself13
    May 16, 2024
    May 16, 2024
