Shocker Extreme
Okay... Starting the box build... I'm going with this design here that way if I decide to change up and go with a tube port I can later on...
Driver Properties
Type: Standard one-way driver
Company: Shocker Extreme
No. of Drivers = 2
Mounting = Standard
Wiring = Parallel
Dual voice coils = separate
Fs = 29.61 Hz
Qms = 7.636
Vas = 56.97 liters
Cms = 0.11 mm/N
Mms = 267.8 g
Rms = 6.399 kg/s
P-Dia = 277.3 mm
Sd = 603.9 sq.cm
Qes = 0.367
Re = 4.01 ohms
Le = 6.47 mH
Z = 87.4 ohms
BL = 23.32 Tm
Qts = 0.35
no = 0.38 %
1-W SPL = 87.95 dB
2.83-V SPL = 90.83 dB
Box Properties
Name:
Type: Vented Box
Shape: Prism, square
Vb = 3.52 cu.ft
Fb = 36.41 Hz
F3 = 34.41 Hz
Fill = none
No. of Vents = 1
Vent shape = rectangle
Vent ends = no flush
Hv = 6 in
Wv = 6 in
Lv = 18 in
After getting the box built and started working on the square port ran into an issue... so yet again I am changing it up lol...
going with 2 4" round ports @ 10" length each... giving me 3.9Net @ 36hz ... thing is majorly braced.. should not have any flex at all... I will update the build log later.
cyn
cyn
Orange, Texas
cyn
