shaving with razors?
Well according to his user title he won't get fooled by that description again.
lawl
Lol.. you never tried using your dads razor when you were really little?
I was saying I did it once, and shaved my lip... Hurt really really bad.. lol
i did. but i wasn't pretending to shave i was just playing with it. and i cut my finger pretty bad //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I don't shave all the way down to my face and only do it sporadically...maybe 2 - 3 times per month. I use a beard trimmer on it's lowest setting and seems to work well. My face is pretty soft, so a little stubble makes somewhat more manly.
Mach Fusion Gel, and Mach Fusion Power razor.
I've had full facial hair since I was a freshman in highschool... and I can't really go against the grain. Maybe with a brand new blade, and after I've gone with the grain first...
Anyways... I always use hot water, lather good, then shave running the razor under the hottest water possible in between strokes.
After you've used something like a Mach Fusion, you'll never want to go back to any of the lesser blade models... they just ****.
nG
Merkur Futur Safety razor, Double edged platinum coated blades, Silvertip Badger Hair brush, taylor of old bond street pre-shave oil and shaving soap. Other than a straight razor, you will never get a better shave than that.
fusion razor with gel not cream. gel covers more area with less gel and less irritation. i shave against the gain (closer shave that way). i shave my face and head. your skin will prolly be irritated for the first couple times but go against the grain its better IMO
nivea shaving gel, the kind in the white can with a fusion razor (no battery)....smooth like butta. Also the blades are very expensive and what makes them dull is water drying on them. If it hasn't been said already, dry the blades with at least a towel but preferably a hair dryer and you can use them indefinately. I use mine 4 - 5 times a week (b/c of my job) and one cartridge will last about 5 months for me when i dry it completely each time I use it. Those cartridges are expensive.
yne721
SWINE FLU!!!!
yne721
Maui/Detroit
NE14MX
