walterdixon
Ok, here it goes.
right now my system consists of a Kenwood KDC-222 H/U (mistake) and JL TR650-CXi's in the rear.
I am soon getting a set of Aura MR62 6.5" components for the front doors, which I think are rated around 75w RMS.
I am also planning on running a Koda8 until I save up for a Koda10.
As for amps, I will be ordering a Profile CL640 (75w RMS x 4 @ 4 ohms) for the interiors, and a Profile CL600M (150w RMS x 1 2 @ 4 ohms) for the sub.
The h/u I have only has 1 preout. Will I be able to splice RCA's off that one preout, or am I going to have to upgrade before I do the rest of the setup? Eventually I think I will grab an Alpine CDA-9825 (3 preouts).
Also, I already have pheonix gold 16 guage speaker wire run throughout from the previous owner. Will this be good enough for the interior speakers, or should I uprgrade to some 14 gauge?
*deep breath*
Now, as far as amp wiring kits goes, I know I'm going to have to use a distro. block. What gauge power wire/ground wire should I run. And what gauge wire should I run out the other end of the distro. block (I know, very technical terms I'm using) to the amps?
I know this is a lot to chew on, but I'm just lost with what to do right now.
P.S. - if you strongly feel I should change my mind on any of the products I mentioned above (aside from the comps.) give me alternative suggestions.
*deep breath*
