Settings on amp
Varinabassing
Ok i see the lowpass what should i set this too ? the box is tuned for 35 and the filter goes down to 32. Then there is a knob on the bass remote should that be set to like 32 too or higher not sure about that. And the infrared filter i think is what its called says it takes the low low notes out but i want them just dont wanna over do the sub or amp I have my gain set to 3/4 is this ok ?? Oh almost forgot its a rockford t2000bd. the sub is a btl 15 Fully loaded .. Help Please Thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
All i see on the amp is a crossover and infrasonic and the infrasonic is has only on and off the crossover goes down to 32
Infrasonic is another name for subsonic filter.
If theres no adjustment on the amp its pre-set at a frequency the amp maker chose.
Probably at 20-25hz, but you would have to look in your manual to find out what it is.
i just looked through the book and it says engaged at 28htz so i guessing nothin below that is going to be played if i have it on.. So turn the cross over to 32?? wat about the knob crossover is that the same as the other one and should be at 32 too
With a ported box tuned to 35hz you should leave the infrasonic filter in the on position, its there to keep notes too low for your sub to play from damaging it.
The crossover should be set to blend the sub with your front speakers, usually 60-80hz with 6.5" speakers up front, or 80-100hz with 5.25" speakers up front.
The correct crossover point is whatever sounds like the best blend with you front speakers to you.
Varinabassing
Varinabassing
Richmond,Va
Varinabassing
