Setting the gains, good to go?
Myster
I am getting ready to set the gains of the two amps with the voltmeter and want to verify the voltage settings.
US Amps IS 4085
Power: 85w x 4 @ 4ohm
Sqrt(Power*Resistance) = Voltage
Sqrt (85*4) = 18.439 volts
Elemental Designs Nine.2x
Power: 600w x 1 @ 4ohm
Sqrt (600*1) = 24.49 *2 = 48.98 volts
Thanks.
-sean
US Amps IS 4085
Thanks.
-sean
Looks good man...remember these numbers will vary with votage and actual amp output....so use your ears too!!
Myster
Myster
Scottsdale,AZ
Myster
