Setting gains: Different voltage with diff hz test tones?
Lurius
Well I am once again, setting my gains(changed some stuff on the amp) and I first set the gains with a 50hz test tone.. but I was curious and tested it with a 35hz test tone and it is saying 55v instead of the 41v-42v I was getting with the 50hz tone.
Is this safe? Is this normal? What causes this?
Thanks again guys lol, sorry about so many questions, I just dont wanna fry my equipment!
-Lurius
Where is your low pass crossover set? What about any bass boost? Having either of these turned on can affect the settings.
I actually just went outside a while ago and changed it up again.. I turned off the bass boost on the headunit(which works at 40hz), then changed the settings on the amp to 35hz and +12db. I re-tested the gain and its right at 42v now@ 35hz and lower at 50hz.. which following that same pattern as before, im willing to bet that @ 30hz it will be higher voltage than when on a 35hz test tone.. This making sense? Im no pro lol.
Thanks,
Lurius
PS: Im not tuning it for competition or anything, would just like the get the most power out of the subs. If I can ever get a good box design for under the rear seats then i may go to some better subs with higher output, but for now im stuck with .7 cubes and 5.57 depth =(
The next thinkg to ask is do you have a "true RMS" multimeter. A lot of DMMs for RMS just take an average based on a set sampling frequency. A true RMS actually calculates the RMS which is different from an average. With a lower freq, the average value will show as a higher voltage than the RMS.
I put bass boost on +0db on both the amp and the head unit. I really only needed it so I could listen to some music without the bass booming too loud, but I just realized the bass boost on the HU has a - setting as well lol, so I can just turn it down there when I have to.
Thanks guys, it seems to be holding out good now, did a 20hz-100hz sweep test tone and the voltage did fluxuate still on different hz, but never got above 42v, so im happy and satisfied it wont F anything up!
-Lurius
Lurius
Lurius
Arlington, Texas
Lurius
