seriously help me with this. sub pop
About your ground, you say 2 wires connected by a bolt. Do you mean you used 2 different piece's of wire to make 1 longer ground wire? A friend of mine did something similar by combining two pieces of 4 gauge wire to make his ground reach the battery in the front and he had a turn on pop from hell but when we replaced it with single piece of 4 gauge it went away. I'm not sure if that's how you have your ground done but that might be a weak point if it is.
Yes it is, and i figured it was a stupid idea but i went ahead and did it as a quick fix
for my lack of ground wire, ill disconnect it tomorrow and test it again.
Checked the ground wire, thats not the problem still happens. I'm going to swap
out the HU tomorrow, if that doesn't work off to the shop, let them deal with it,
I'm fed up with this shit.
I'm back and i'm here to tell you that the Treo and the Fi combination refuses to work
I am now asking if i can sell all this shit to you guys. I've gone to local shops to test
the amp, that works fine. The guy told me its the sub, he said its blown. Went to a
different store dropped 30$, yes 30 $ to test the sub, works fine. The sub even plays
music to extent until the am goes into protect. The amp puts out wattage on the DMM
when i tuned it. I have redone everything twice or maybe even three times and its hopeless.
So would any of you guy this equipment? Or is someone close enough to me with a working
electrical that i can drive to to test it on your car, I'm getting pretty desperate.
*if your response is not serious don't bother, I'm tired of the CT bullshit
cmon, ill let the amp go for 400 obo, and the sub 200 obo and will do any
test and take enough pictures to fill a photo album with. I'm just wondering if
Anyone will even consider buying this stuff. I'm 100% it work just not for me.
shellfish
shellfish
Concord. CA
shellfish
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
