seriously help me with this. sub pop
shellfish
+Long story short my sub pops when the amp turns on and pops really loudly if:
-head unit volume past 25
-car door closes
-any random times, during driving
Then the amp goes to protect and wont turn back on unless i restart the car
+I have the following things done:
-1awg power wire
-1awg ground (two wires connected together via bolt)
-Head unit rca out ground to the head unit
-another 1awg ground to sub frame of the car
-yellow top under the hood sitting @ 14.40+ while music playing
+Potential problem areas:
-My HU power runs from batt to 10a mini blade to hu
-When i was trying a different set of RCAs the same ol' thing happened
but the RCA cables were really hot, i guess the amp was trying to ground via RCAs?
- Changed was the big 3 engine to frame ground,
its now engine mount to strut bolt if that helps
This is driving me crazy i've worked on this thing all day yesterday and the
install for the past week, and I'm just about ready to push my car of a cliff
The pop noise could be a sign of inadequate grounding of the HU. That is part of the symptoms of a ground loop problem as would engine whine (ALT noise) coming through the speakers.
Well I'm trying to isolate the issue, If you guys could just make a list of things
for me to check over that would help a lot. What i do is i go through the possible
issues and then the things i already checked in the first post.
Sounds like a ground loop, or your headunit output is balanced rather than unbalanced. It MIGHT be grounding the outer terminal of the RCA out inside the amp, but usually there is a resistor to ground there of about 1k value, and it sometimes gets fried due to this.
Seemed like a ground problem to me too.
But I have a 1awg from battery - to amp AND i have a good frame ground.
And it does seem like its an rca issue because like i said I tested it with a pair of
RF RCAs and when the sub burped and the amp shutdown the cables were
really hot, its just i already grounded the RCAs and the HU and i'm pretty much out of ideas.
How would i fix the RCA balancing?
Keep in mind that the sub/amp do work @ low levels and without being disturbed by anything (door shutting, car moving etc)
shellfish
shellfish
Concord. CA
shellfish
