hey quick question. I have an infinity beta digital 100 amp. it is rated at 400 watts bridged at 4 ohms. I have two 4 ohm subs. jl 10w0. so if I wire it in series it will be a 4 ohm load. correct. thanks for the help.
Originally posted by Goddyd4me ok...if you wire it in parallel your probably going to run it at to low of an impediance so you only got series or the other way assuming someone else can verify that it will work....but in series your only going to get 100/sub....so either way your only going to get that unless that other way works....sorry
is why I stressed MOST lolOriginally posted by Jmac Depends on the amp, though ...
I wouldn't be running 2 ohms mono off a Jensen amp ...
