fox_forma
Its a pretty simple question but I keep thinking about it and it is starting to confuse me now. If you have 2 D4 subs wired to run at a 4ohm load it shows the subs basically being wired in series with eachother then parralleled before the amp (correct?) When looking at the diagrams it shows how to wire them, but it shows how to wire the subs together as one. If the subs needed to be wired seperately for each chamber in a box, would you wire each one in series then connect the wires together at the amp to get the 4ohm load between the two? Hope I'm making sense.
