Series or parellel wiring
You only need series or parallel if you are wiring multiple speakers to a single channel
Or if your subwoofer is a dual voice coil
If it's dual 4 wire in parallel to get a 2ohm load on the amp
If it's dual 2 wire in series to get a 4 ohm load on the amp (most 5 channel amps don't work well at 1ohm on the sub channel)
Why not wire the dual voice coils in series for an 8 Ohm load?
John Kuthe...
Leave us alone please, adults are talking here.
John Kuthe...
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
I've ran and installed a few 5 ch amps in the past.
What they're saying is just like any other amp hooking up with speakers the regular way. What's the amp?
Ok seems like a pretty nice amp for the money.
So...if you had a component speaker set consisting for example 6.5" mid and 1" tweeter, and it's impedance is typically 4 ohms, sometimes there's 2 ohm versions, then straight wire them to the amp. No need to cross reference (parallel/series) those. The only part you would have to series or parallel is in the sub area. That amp does the most power at 2 ohms. So if you had a single sub dvc you'd need a dual 4 ohm sub. If your running 2 subs that are dvc, you'd need dual 2 ohm subs. If you had single 4 ohm SVC drivers, then obviously that's when they would get wired in parallel to achieve a final 2 ohm load.
Thanks for confirming that. I have exactly as you stated. The front component speakers and theaters(4ohms) and in the rear are 2 way coaxials. I have just one sub(4ohms): Heres the link.https://www.rockvilleaudio.com/rmw8p/
Is this sub able to be wired up without series or parallel?
That sub is 4 ohms only. If they had made it dvc, then it would be flexable for the user....4 ohms or 2 ohms.
So that said, just plug her into the amp and fire away. May not be very loud but it'll be something.
neil4374
neil4374
los angles
neil4374
