SENS and FREQ LOW and HiGh$$$$$
  • 2
Free_Style
Chicago
I have a phoenix gold 400.2 running 1 12" pwd mb quart. I don't how to set up the amp. What does Freq. and Sens do? How should I set up the AUX and AMP it has
Speaker Outputs HIGH PASS- AUXILIARY Outputs LOW PASS.
So> LOW PASS-AO> HIGH PASS,
SO> FULL RANGE-AO> FULL RANGE,
SO> LOW PASS- AO> FULL RANGE.
What works the best for a SUB?
FREQ. stands for frequecy. Your amp has a built in crossover, you should have it set to LOW PASS. The FREQ. knob should be set to about 80hz. or lower.
SENS. stants for input sensitivity, set this to match the preout voltage of your head unit. It's basically like a gain or volume for the amp.
AUX is only used when you want to hook up a 2nd(auxillary) amp, but your head unit only has one set of preouts. Than you could use your amps auxillary outs and crossover with the 2nd amp. My friend calls it "piggybacking".
594
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
744
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Free_Style
Free_Style
Chicago
indosia
