selling my old box and I'm not sure if this will work?
Mr.meyhem
the box is 30 by 20 by 11. port is straight back with a 2x4 bracing right next to it.
from the 2 by 4 to the end of the box it is roughly 22 inches. the person buying wants to put in 2 12" dual subs. 175w rms each. I'm thinking i will have to mount them also diagonal from each other?? I'm putting a new face plate on the box because i had a single 15 in there before.
so would this work? or should i make them diagonal the other way? will it matter? box is tuned to 34.7 hz if it matters. any other ideas????
yeah its about 2.6 cubes right now. but adding another face should make up for the 2 subs. they only need a 3 or 4 inch mounting depth. person picked up the subs for free and just wants a decent box. and this would be better than a walmart box right?
tuning would also depend on how much space the subs will take up as well.... It might "work" but it might not perform very well, its a crapshoot
any advice on the diagonal positioning of the subs? does it matter which if the one closest to the port is higher vs the one farther away? maybe the one closet to the port should due lower so its not in the way of the port?
That should be fine. Most subs are more than 12" though, you might want to measure them to make sure they will fit.
they are cheap subs so i can't find the specs. they r a 175w rms 500w max dual brand sub. single 4 ohm i can't find cut out or the actual size
everybody in my school thinks that duals are the shiznit, they think that the only thing better is the l7..... I be facepalmin err day.
ik right lol.
I'm just trying to get rid of the box and let someone else use it. they won't sound amazing in any box cuz they r 26 buck subs. but hopefully this will be better than a prefab.
Mr.meyhem
Mr.meyhem
Cold as F***, MN
Mr.meyhem
