securing box without drilling through floor
screw down to all four corners away from your gas tank,and you have an unlimited flooring to screw down box/amps/dist blocks/fans/whatever??Way to go..imo
ok, and what about sealing where the bolts come through the floor? rubber washers? silicone or some other type of sealant on the bolt itself?
hmm strange..i just happen to be chewing double mint gum too????//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
...//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
going through the floor under the vehicle/silicone/gorilla opoxy.use self tappers,with washers..4-6 is all you need next day hit the screws underneath with some rustolium paint,after epoxy/silicone dries..what i do on all my vehicles ive ever done w false floor..i like the epoxy best.
ok cool, do you mean use silicone THEN use gorilla epoxy, or either?
either..just be sure clean around the penetration best you can,approx quarter sized enough for the sealant,in whichever you use,with alcahol,and rag,even dawn soap n water,then alcolhol..in order for an excellent seal,once it dries by next day,and you hit it with the paint/rustolium..itll be like a hard weld feel/help protect/repel from water ect.thats way i do mine
knotdrummer88
knotdrummer88
Toledo, OH
Sub Woofin
