Secrets/Tips to making an enclosure
also have a 40oz and a blunt with you, take certain breaks in times, it will keep you focused.
//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif :naughty: //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
caulk and silicon is the devil. i only us a little on my terminal cups. if your cuts a strights u wont need silicon.
you keep telling yourself that //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
straight or not, sealing internally is gold.
ALRIGHT, all the boxes ive built sealed and ported are airtight. if you use enough glue shoulnt have to use silicon. a friend of mine uses a spray sealer, that actuly penatrates the MDF. its used for roofing.
I wouldn't call them a must...I also don't like just drilling a hole and sealing it. If you're not going to use a terminal cup, at least get a good set of binding posts and use those to attach your cables.
But if you do anything with bi-wiring, then they become very attractive to use //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Chrisku13
Chrisku13
The asscrack known as Arizona
Race
