Product Specifications:
13" Single 4 ohm SPG Series Oval Subwoofer
Power Handling:
RMS: 1000 watts
Impedance: Single 4 Ohm
Polypropylene cone woofer
Foam woofer surround
RadialVent® cooling directs airflow around the voice coil for increased power handling
RVC™ (Removable Voice Coil) allows coil to be exchanged without removing the woofer from the enclosure
SPS™ (Soft Part System) technology allows for cone assembly removal
SPG555 can be field-stripped and custom painted, powder-coated, or plated for a custom look
Simplified mounting with the integral sealing gaskets
3-1/2" Voice coil
3-3/4" peak to peak excursion for devastatingly accurate, deep bass output from small sealed enclosures
555 cm2 of surface area
Compatible with the SPG-TR passive radiator
Frequency response: 20-350 Hz
Sensitivity: 87.7dB
Xmax: 22mm
Mounting Depth: 8-1/4"
Cutout Dimensions: 13-3/16" x 10-7/16"
