sealed drawer
big drawers
//content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif
Ported box make more than boom boom, if sq you want it can be achieved with box built proper. SPG ported boxes it like and sealed not worth the space saved with sub this is. In Soviet Russia drawer build you!
How does one get good SQ on a system tied to a bicycle?
Lol you guys are all ***-holes. I just made my box double walled sealed at a little over 1 cubic foot. and it sounds awesome. Good luck with your drawer.
Product Specifications:
13" Single 4 ohm SPG Series Oval Subwoofer
Power Handling:
RMS: 1000 watts
Impedance: Single 4 Ohm
Polypropylene cone woofer
Foam woofer surround
RadialVent® cooling directs airflow around the voice coil for increased power handling
RVC™ (Removable Voice Coil) allows coil to be exchanged without removing the woofer from the enclosure
SPS™ (Soft Part System) technology allows for cone assembly removal
SPG555 can be field-stripped and custom painted, powder-coated, or plated for a custom look
Simplified mounting with the integral sealing gaskets
3-1/2" Voice coil
3-3/4" peak to peak excursion for devastatingly accurate, deep bass output from small sealed enclosures
555 cm2 of surface area
Compatible with the SPG-TR passive radiator
Frequency response: 20-350 Hz
Sensitivity: 87.7dB
Xmax: 22mm
Mounting Depth: 8-1/4"
Cutout Dimensions: 13-3/16" x 10-7/16"
Power Handling:
RMS: 1000 watts
3-1/2" Voice coil
Sensitivity: 87.7dB
Xmax: 22mm
lmao, what an idiot
gozaine
gozaine
LARA
xSPLoder
