sealed boxes
I noticed my system lacks a lot of bass-midbass in rock songs,
should I build a sealed box for my 12'' dc lvl 4?
what do you think the frequency range for a sealed would be vs a ported 32.5 hz
Ported enclosures act exactly like a sealed enclosure anywhere above ~1.5 times the tuning frequency. Going sealed isn't going to fix your problem. Try going with a smaller ported enclosure or a better enclosure design.
I used to have 2 12'' kicker cvr's (older model ones) in a sealed box,
my dc lvl 4 doesn't seem to hit the higher notes that the CVR's did.
my lowpass is set a little past the middle (between 30hz and 300hz)
what do you guys think I should do?
raise the lowpass? put it in a sealed box? build a ported box and tune it higher?
Typical FIX!
I would build enclosyre or somehow outyour mids in a sealed box or well sealed door. Small sealed boxes tend to play higher better, which to me is annoying unless its for a mid. Then your mid and low should blend in together.
When I listen to my music it sounds as if I dont have a sub, as though the mids are playing the lows also.
I used to be able to tell the sub was behind me but now lowpass over at around 75hz it seems to blend well.
RJesus
RJesus
Philly
supermaxx123
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
