sealed box for RE SX ? good/bad ?
brian84corvette
hey guys,
I seem to be in a bind here.
just got done all the math on my new box build,
and it seems like im pretty f'ed.
specs for my sub - tell me it wants 5.5 to 8 cubes ported ( not including port disp.)
and what I can fit in my car is only - 6.64 cubes
after taking away space for the sub and port
it leaves me with 5.59 cubes.
still with in the specs of re - but just by a hair. (re sx 18)
so - I was thinking maby just running it in a sealed box
wich would leave me 6.42 cubes to run sealed.
im thinking it should still sound good - but im a little worried about
heat build up inside the box ? - since its going to be sealed.
im all over the place with this - wich is made worse by its raining outside
right now and I cant start building - so time is making me second guess
my build plan for the box...... grrrr
if it was your rig - would you do sealed at 6.42
or would you do ported at 5.59
power is coming from bxi1206d - so it can see 1k watts realisticly.
wich is rms of the sub. - also the car is tiny inside ( my vette )
if that makes a diffrence at all.
spl blazer says it should be ok if its in the manufactures specs,
but smaller boxes can handle more power - mine is just rms power
probly nothing more - even tho amp says 1200w - hifonics is just good like that
I guess...... ?
lmk what you guys think.
thanks again
an 18 ported in 5 cubes is small, but its not ridiculously small...I'd go for it, worth a try, if it sucks, seal up the port opening and you've got a big sealed box
hell I've got two MJ's in like 4 cubes a piece (granted they aren't as heavy-duty as higher end 18's and don't need as big a box, but still...)
I had 4-15" RE SX subs and they had around 3 cubes each and that was a bit small. I did a 152.9 on the term Lab meter with that box. I also ran one of the SX 15's in a 2.5 cube box and it worked ok. I say go for the ported box.
edit, also that SX sub does not work well at all in a sealed box,
I say go ported, you can also try using Aero's instead of a traditional slot port as they do displace quite a bit less air, you may be able to get a bit more space. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
I'm pretty sure RE doesn't recommend sealed for the SX's. There is usually a reason for that //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I was thinking of aero's too.
usualy im a slot port kinda guy -
but in this case where space is such an issue - I had been thinking of them as an option.
any ideas where to get a pair of them ? maby a pair of 4" size aeros at 30 hz might be good ?
I was thinking of aero's too. usualy im a slot port kinda guy -
I'd go for 2 6" aeros if you can fit them.
brian84corvette
brian84corvette
coral springs FL.
mobeious
