Sealed 12w3v2's
Go to http://www.jlaudio.com
go to the 12w3v3 page.
Click enclosure recomendations and there will be a box blueprint for you. I believe they like 1.25cf last time I checked..
edit: here
Recommended Sealed Enclosures
Subwoofer Volume
(net int.)
External Dimensions
(Width x Height x Depth) F3
(Hz) Fc
(Hz) Qtc
12W3v3-2 1.250 cu. ft. / 35.4 liters 23.0 in. x 14.0 in. x 10.0 in.
584 mm x 356 mm x 254 mm 41.8 50.4 0.96
12W3v3-4 1.125 cu. ft. / 31.8 liters 23.0 in. x 14.0 in. x 9.25 in.
584 mm x 356 mm x 235 mm 43.7 50.2 0.83
12W3v3-8 1.250 cu. ft. / 35.4 liters 23.0 in. x 14.0 in. x 10.0 in.
584 mm x 356 mm x 254 mm 41.5 50.5 0.91
i wouldnt do it.
but whatever.
my w3v2's sounded like crap sealed.
the box was i think like 3 cubes
mine sounded good sealed...not loud enough for me though //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
No you need to listen to yours. If you don't think they sound right then they don't. Change it up. Just because it sounds right to someone else doesn't mean it will sound right to you...
twanked~ls
THE REGAWL
twanked~ls
kentucky
ivan0507
Mike Mccabe
