Sealed 12" Recomendations
The sub and port would face up. The depth will be from the floor up and width is from the back of the car to the end of the storage area. Hope this helps.
Ok man, I actually did a box for a camaro before, you know basically the same car. Where in the car is it going? I had a box where the port fired to the right and it sounded really good. Just a thought.
Ok, I've got a simple ported box design you could try for the Fi Q. Now keep in mind there are many other subs that would work in you application, but the Fi Q is good. This design uses all your space. The internal space with be about ~2 cubic feet tuned to 30-31 hz, with 29.25 square inches of port. The only issue with a sub like this is that it likes low tuning, and that generally means a longer port, which means more room taken up by the port, but it'll work.
530racer
530racer
NorCal
Buck
