SE vs SS which one?
Yeah that would be nice with one of the 1100d's!!
What 1100 watt amp is it you have?
And yes one SE would run alright off of 800 watts but i think you would get more out of 2 of them ported. I had 550 watts on each and they could take it decently!
For a 10 they actually recommend 1.5^3 @30hz for SQL You could fit that behind your seat no problem
You are ignoring their sealed enclosure recommendation, which imo should be considered if space is such an issue. Sealed, a xxx 10 should thrive in a box half that size (0.7cuft), which is pretty small. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i have an SE12 in a reg cab receiving 800 watts RMS daily. playing at high volumes in my f150 reg cab it makes peopel sick
for such a small cab its ENOUGH. even the 10 by itself would be fine. keepin mind hte tiny airspace and its sitting right behind you or hte passenger
Directed 1100d, i think im gonna go with the SE10 or if i could find SEXXX that would be great lol, see airspace isn't a problem, just mounting depth is all im worried bout i need somethin like 5 7/16 at the most
Get bucket seats, invert the sub between the seats. Looks cool (imo) and gives unlimited mounting depth in a regular cab pickup. Could put a crazy sub in your little truck that way. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
holy shit thats like the best idea i never accually thought of that lol could would it sound SQ wise tho any different? oh and your blazer is bad *** i have a 89 s15 jimmy as well
The only SQ issue you would have is 'motor noise' would be a bit more aparent, seeing as the sub's motor will be inverted and sitting right next to you. But lets face it, if you're trying to squeeze a 'supersub' in your regular cab, you are not building an all-out SQ setup. I doubt the motor noise would bother most people, if they even noticed it.
If I had a regular cab and wasn't going to do a blowthru, Id definitely be inverting a sub between the buckets. Its a relatively common install in reg cabs now a days. Good luck. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Jdizzle
tha dirty dizzle ;)
Jdizzle
Carthage, NC
Jdizzle
