se 15"s could be louder?
The box looks pretty solid, how's the bracing? Definitely add a second big battery and lower your subsonic filter. If your peeking at 33hz and your SSF is set at 30hz your losing alot of potentially loud low-end. I had a pair of 18's installed one time and the shop set my SSF at 30-33hz and it sounded like shit, I lowered it to 15hz and was braking roof braces. Just watch the excursion on the subs and you'll be fine.
Drew
how much room is between the box and the rear tailgate ?
have also seen a thread on here about a guy gaining nicely on tl score
by adding sound deadning to the roof above where the woofs are firing at.
makes sence. if the roof is solid, the sound will bounce back, instead of flexing the roof so hard.
that way its not wasted energy in the sound wave.
yeh, i really need to get some deadner...the rear liftgate sound like ***...LOUD VIBRATING ***!!
and theres a good 6 inches atleast between the ports and door, i can put my fist between the two with room through the window
***no thread jack*** i just got a quick question...ive had se's before waaaay back...but i just bought 2 15 dual 4 se's for my cutlass that i used to have 3 L5 15s..did i downgrade or upgrade?
let'me try again.....
p><p>Nice%20score%20man...147%20@%20that%20low%20of%20a%20freq%20is%20really%20good....I%20think%20you%20might%20be%20having%20the%20same%20problem%20as%20me...We%20can
One question...do you have the rear vent windows?? are you losing a lot of air out of there?? I know mine is pretty bad....thinking about sealing them up...
luv2shrOOm
In my TONKA !!!
luv2shrOOm
bigbangtheory
