se 15"s could be louder?
On my se's I did 144.0 3.9 cuft tuned to 38 hz. And did 143.8 4 cuft tuned to 33 hz. So a little increasein the differant tuning but not huge. All done db drag style sealed I think they sounded a 100 times bettter tuned lower this was done on a zx1500.1 just a red top in front stock alt. So maybe more juice wouldve helped don't know.
wow. almsot exactly the same setup im soon running. i got half the stuff. 4 15 re se, off 2 aq2200d, in a 97 expedition. have any pics of your setup?
no but i'll try to get some up in the morning
HO alty, bigger battery up fron and a dry cell in the back like a 2400 Kinetik, big 3 and it should help some. Might not get to 150, but you might.
Electrical is a big part mang.
I am the same though, want my tunes and usually just deal with the lack of power and dimming head lights, lol!
I need to do my big3, but it is such a pain in the *** to get to my alty.
Dude, a 147.3 is a **** good number for no electrical, especially at 33hz!!! You might even be louder if you try lowering your subsonic filter a bit. Those subs will get the lows like crazy.
Drew
they get loud i'm doing a 43.5 with a single se 10" reconed with better parts.
tune higher for a louder # would start @38hz and keep cutting the ports. are ur ports low in the enclosure? how much room between the tailgate and port? is ur box braced well? ur alt is plenty with that amp, get a 2nd battery kinetik 2400 or pm 3100!
I would add a more battery and upgrade the wiring first. Then start looking at retuning the box. You will get more sound with some more work.
I have seen SE's in small sealed boxes hit some good numbers with enough power, you should be able to do well with a ported box.
bump for pics
here ya go.. 4 15" se's with 4 6" ports
my.php
luv2shrOOm
In my TONKA !!!
luv2shrOOm
bigbangtheory
