Screws backing out from vibration?
SilverBullet6.0
My amp is mounted onto my sub box, it has an amp rack on it. Last night I heard some rattling and thought it was a sub going bad. After further inspection, it turns out just some screws on my amp and subs were backing out. How can I keep the screws from backing out due to vibration? Wood glue on the screws?
If you must mount the amp to the box. Here is what I do get some rubber around 1/2 think or so and mount it between the box and amp rack. It will help dampen the vibration. It does not completely take it all out but it helps. Also How long are the screws you are using.This makes me think you have way to much flex goin on in your box to be doing this, but i say longer slightly bigger screws
Dammned that looks awesome. be a great picture in a workshop!! I have maybe 6 steel ratcheting type clamps, if that. much like the ones you have...
811
To me.. It looks like the Allen head screws are in the terminals on the speaker inputs on the amplifier. The negative looks like its in there and...
  • Locked
That MRD is a good series of amps ...i may have some extra accesories if you havent found them
SilverBullet6.0
SilverBullet6.0
Malden, MO
spltuscon
    Jun 1, 2024
    May 31, 2024
