SCION TC INSTALL SO FAR.......and building
jonesy
Have to make a few more panels and carpet the entire enclosure over so its seamless! The reason for the already carpeted enclosure, is the fact that i built it years ago and decided to use it as a temp enclosure. when i have time to finish the fiberglass enclosures i started.
now i need to throw in my HC1800 under the hood to complement the HC1400 in the hatch and flush out the eclipse eq that's sitting in front of the enclosure!!
nice install, clean job on the wiring, fit and finish on the amp rack looks a little off but still a nice install. amke sure you post pics when ur finished //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yeah i see what you mean it needs to be pushed down the rest of the way..........i just finished it a hour ago lol
trial and error, i cant tell you how many times Ive put stuff together, decided sometihng else would look better and started over. my truck has been in pieces for 6 months and is finally coming together lol
I also think it would look good if you could find some oem silver to match the install bezel to the dash.
Will have some body work to it so its seamless, and then it will be sprayed the same oem silver the factory used on the exterior!
Hey Jonesy when u coming to NORCAL to help me finish my car? Nice job so far! How long will it last b4 u change it up? I can never keep my setup the same for some reason. My car is in a constant state of turmoil.
Looks like the amp on the right looks crooked. Maybe it is the picture not doing it justice, I don't know.
Looks good though.
probably is, they aren't mounted just at all i just fitted the rack to make sure before i finalized the install!
i woulda flushed the subs in, other then that very clean install. i like the triangle ports, but those SEs can move a fair amont of air so i might be woried about port noise and full tilt
jonesy
jonesy
Castletion Ny
jonesy
