school me what to build a cross breed subwoofer
dtp
I want to build up a custom subwoofer
The coil I have in mine to use is an atomic 3 inch apx coil
I want to know what is the best motor I can use is in my custom design e.g. dd, mt or btl
I will be using the same basket from atomic so the spiders will line up from the atomic kit
So please help, offer me some suggestions
Thanks
Is neo motor the best? And y
i want to try it
i heard a built subwoofer with a shocker motor and mmats jug 2000w coil kit that sounded real good
give me some idears
hi school me got qustions
1.what is the best motor to use to build up a spl beast
using 3inch coil
the cone and coil kit will be atomic apx or apxx sorft parts will be mmat dreadnut
2.what are the differance between motora beside their size (materal wise )
3.does basket make a differance in their different designs or jus for cooling
help me i lost baddddddddd
i want to try it i heard a built subwoofer with a shocker motor and mmats jug 2000w coil kit that sounded real good
give me some idears
english language>you there's more then what i put in bold, but those are the main ones i could find
I wrote it back hope this helps u understand my Missions to build a cross breed beast
I really want to build a spl subwoofer
Just buy one and spend time on tuning the box. Having a custom woofer wont make you special!!!
Well, it'll make you special if it's not a hodge podge of parts designed for other drivers.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Most people start with a motor and get the frame and soft parts they want to go with it, not the other way around. That is, if you are really dead-set on doing this, because it plainly obvious you are in over your head so far. But good luck dude.
man use alot of subs
atomic apx and ele subwoofers (12/15)
soundstream xxxx (15)
rockfrod punch and power hx2 (both 15)
orion h2 (15), xtr( 12)and xtr pro (15)
earthquake ls (18)
mmats jug (15)
dd 9500 (15)
jbl gto (12)
lanzar opidrive sub (12)
i have use alot of different brands so i think its time to be different
where are you from?? you dont mind me asking??
N/M its Trinidad, thats why you cant speak freakin english, but its O.K., couse most people living in U.S. cant speak freakin english. lol
dtp
dtp
new york
02parkave
