Saz-3000d Vs Dd Z1?
From what I have seen the powermasters are slightly better than kinetiks but definitely much closer than deka and powermaster. You probably couldnt go wrong with either to be honest.
so even if i could get dekas for quite a bit cheaper (can get them at 10% discount) and since i would not be competing only for daily listening use, the powermasters/kinetiks would still suit me more? or with my situation would the dekas do me just as good?
Indeed. Issues can arise with any amp, when they do it's nice to know that you have a solid warranty to back you up.
If you can find about 30 other guy that want to pre-order some I'll do it *laughs*
id be down for a saz-7000d rather than 2 3000s //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
That was on a 16v system where at worst it dropped to mid 14's in voltage. You will not see that in your car without fairly strong modification, keep that in mind.
The atomic 3000.1 shares the saame board, but there are plenty of other things different with it vs the Sundowns. Sundowns do plenty morep ower than the Atomic, fyi.
Anywho, although I used to love DD. Sundown or RD or another similar zenon based board would be your best bet for daily power. DD is a nightmare to deal with in regards to customer service
sorry to be off topic but do you have any real proof of this statement? ive been wanting someone to compare boards for awhile now but i guess no one wants to take the time.... see page 7 second post i have all the specs on the atomic board ready for comparison to the sundown http://www.caraudio.com/forum/showthread.php?t=298891&page=7
Is that a promise?? I am serious. I would take 2, I know someone else that is a Team Member that would like 4, theres 6 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If you go with dekas I would put two in the back and that will be just fine as well. I just wouldnt want to run only two for the way it sounds like you listen to music.
if i were to do 1 deka under hood and 2 in back which size dekas should i use (going in an integra or hatch)
i also dug this up from roe, this was his statement
"the d3100 should be the same as a deka 9A31. Both the deka and the powermaster are true AGM batteries where the kinetik is not.. it is sla/"agm"
also just so you know the deka's are highly under rated in specs by the company... they put out much more power than what their specs say.
As said before durring testing on the 9A31 it put my tester to the max rating and still wanted to keep going. Before the machine pegged out it was putting out over 1400CCA and 2800CA and would have kept going if i had a big enough tester."
-Brock Jones
how accurate are his claims?
-Brock Jones
Than believe that if you want. I have used both and can tell you they are not the same.
But its your decision and you have to live with it. :shrugs:
Jegs carries them. I am not sure on the cheapest place to get them.
But in all honesty I would actually go with the three dekas as it probably will be cheaper in the end. Its a little more weight and room but if you can make it work that is the route I would go.
Or if dead set on two batteries you should look into the kinetiks on millionbuy as that will probably be cheaper than powermasters as well and will work great for your application.
I think you should've said a little more unrealistic number than 30, maybe 300 or 3000, because i'd bet money we can get 30 people willing to sell everything to pick up a sundown 7k
pinoywitboom
pinoywitboom
Da Big Isle
njaykaplan
