saz-1500 & saz-100.2
2 options:
1) big 3, isolator, new 2nd batt
2)big 3, relay, 2 new batts
with 1000w. your big 3 needs to be done. imo i would isolate the 2nd batt. relays just turn on and off. they allow both batts to equalize possibly causing problems down the road. just make sure the new batt/batts will handle that power.
I wouldn't think you'd need a second battery just for that, what size is your alternator? I'm pretty sure if you get a kinetik 1800 up front or something equivalent and a batcap 800 or kinetik 600/800 in the back you should be fine. I'm putting almost that exact same setup in my truck with a 60 amp alternator so I think you'd be fine.
I have an 04 accord and i'm running a saz1500 off the stock battery + alternator.
no problems power wise... so far //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You'll be fine with your current electrical, if you want to go pick up a new YT than that gives you that much more assurance, but you should be fine, just set your gains conservatively and keep an eye out for voltage issues.
Jared530
Drop bombs
Jared530
Sacramento, Ca
DB_DRAG_SPL
    Jun 24, 2026
    Jun 24, 2026
