Saz-1200d runnin .5 for Jacob!
Light-Foot
Okay Jacob I really need to know if the 1200d will handle .5 on what I got and will be adding.
06 Silverado
-145 amp alternator
-Red Top 1000
-Will be adding Audio Technix Big 3 1/0 and 1/0 Amp kit
-I have a Dual 1 Z v.3 in a kerf ported console box 2.024 internally and 2.78 overall tuned to 33hz
Right now on all stock except the Red top I hold 15.40 volts so with the Big 3 should be a lot better
Will the saz-1200d be okay to run .5 daily? would love to have saz-1500 but im not waitn till april 30th bc of backorder.
Every saz series amp ive ever seen or run will handle .5. all day on good electrical..so i dont see why the saz1200 wouldnt
---------- Post added at 01:25 AM ---------- Previous post was at 01:24 AM ----------
But id say u will need at least one extra battery
How are you sitting at 15.4 volts on all stock? Is the red top under the hood or in the rear? Id keep a good size battery in the rear, but you should be fine at .5 ohm. Also, I believe you'll lose your warranty if you run below 1 ohm.
Yea his volt meter must be off.and he didnt set it ...and if u have to run .5 i would just buy a used saz1500 thy are everywhere ..instead of.wasting.money and warranty on brand new amp
Thanks for the opinions. Actually your right I havnt touched my volt-meter, it says im at 15.8 but with my greenlee meter is says 15.40 when im checkin my power strait to the amp. if you want me to post a picture I will.
I had an Alpine MRX-100.1 on the z v.3 before running at 2 ohms which is max power on that amp. How do you think the saz would do at 2 ohms? would it be enough?
Light-Foot
Light-Foot
pikeville, ky
Light-Foot
