Safe way to disconnect amps?
yne721
SWINE FLU!!!!
i have to take my two amps out of my car tomorrow because i'm taking my car to my mechanic on monday. Since i've never uninstalled anything, what's the safest way to go about taking my two amps out? Take the fuses out of the power wire first then disconnect all the wires?
Remove the fuse under the hood.
Quickest way.
nG
I don't have a fuse under the hood //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
my battery is under my seat, which is under my false floor which is under my amps. that's why i have to take them out for my mechanic..
but thank you for the help everyone. so if i disconnect my negative on my battery, i can disconnect all the wires on my amps, then after they're out if i take out the fuses on my power wires i shouldn' thave to worry about a hot wire right?
Well, if you take out the fuse from the battery underneath your false floor... then you wouldn't even have to worry about taking off the negative.
nG
yne721
SWINE FLU!!!!
yne721
Maui/Detroit
ngsm13
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
