*SA-8 V2* Which Box Should I Choose
  • 4
Kastlez_
Bay Area, CA
Both are around .75ft^3 @ 35hz
One has 1.25" Port
The other has a 1" Port
BOX 1:
single sa8v2 @35Hz:
Enclosure Specifications:
Fb = 35.3 Hz
Vb = 0.72 ft^3
External Height = 10 in
External Width = 22 in
External Depth = 12 in
Port Width = 1 1/4 in
BOX 2:
[quote name='kushy_dreams']A 4in round port would need to be 26+inches long to be tuned to 38hz. When dealing with small boxes and large ports, its easier to use a slot. I forget the specs of the box that @itsblown and @121jiggawatts used in their sa8 build, but when we metered it, it played relatively flat with good low end extension into the mid 20s.[/QUOTE]
half external half internal . like a baws
Yeah, I'm definitely trying to stay away from external ports. Any information on the box builds you listed? I checked their profiles but couldn't find anything... do you know if the builds were for 1 or 2+ SA-8's?
thanksit says .75 @ 34hz so I guess i'm on the right path.
'Out of respect to ram designs im not going to say the exact dimensions but its tuned to 34htz //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
if you want Im sure@%1; will sell you the exact box we used and its **** good like kushdreams said it plays completelyflat down to 27htz and up to 50 or so
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
It's fine to mount to the box. A lot of show car SPL setups have amps or other electronics mounted directly to the wood frame of the box or on an...
21
188
Kastlez_
Kastlez_
Bay Area, CA
Kastlez_
    May 20, 2024
    May 20, 2024
