S4 vs PDX4.150
jblayz1
Digital Designs-
Series
S
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
20 Hz - 500 Hz (200 - 5 kHz) at 24dB/Oct
Variable Low Pass Filter
50 Hz - 500 Hz (500 - 5 kHz) at 24dB/Oct
Tested Voltage
14.4V
Tested THD
1%
Power at 4 ohm
100W x 2ch + 200W x 2ch
Power at 2 ohm
150W x 2ch + 300W x 2ch
Damping Factor
>550 @ 2 ohm
Power at 1 ohm
175W x 2ch + 350W x 2ch
Power at 4 ohm Mono
300W x 1ch + 600W x 1ch
Power at 3 ohm Mono
350W x 1ch + 700W x 1ch
Max Dynamic Power
400W x 1ch + 800W x 1ch
Efficiency thru Output
64%
Dimensions - mm
390 L x 235 W x 53.4 H
Dimensions - inches
15.35 L x 9.25 W x 2.1 H
Signal to Noise
95 dB
Shipping Weight
16 lbs
Alpine PDX4.150
RMS Continuous Power (at 14.4V , 20 - 20 kHz )
• Per channel into 4 ohms (≤1%THD+N) 150W x 4
• Per channel into 2 ohms (≤1%THD+N) 150W x 4
• Bridged into 4 ohms (≤1%THD+N) 300W x 2
S/N Ratio (IHF A Weighted , Reference: rated power into 4 ohms) 100dBA
CEA2006 S/N Ratio (IHF A Weighted , Reference: 1W into 4 ohms) 78dBA
Input Impedance 10k ohms
Frequency Response (+0, -1dB) 20 - 20kHz
Crossover Frequency ( Variable , L . P. F / H.P.F / OFF Selectable)
• 1/2 ch 30 - 400 Hz (-12 dB / oct)
• 3/4 ch 30 - 400 Hz (-12 dB / oct)
Input Sensitivity (V / at 10k ohms) 0.2 - 4.0V
Dimensions • Width 257mm (10-1/8”)
• Height 62mm (2-7/16”)
• Depth 192mm (7-9/16”)
Weight 3.11kg
these are for a front stage. opinions?
I have the S4.
The S4/m1a is about the same price as the 1.1000/4.150 combo.
Here is some things to consider:
1) Are you going active
2) What drivers did you select
3) How much space do you have
I chose the S4a/M1a combo. It wasn't cheap but works well. In retrospect, I would have chose the 4.150/1.1000 combo as I could have really used the space.
But here is another consideration. Let's pretend you have a passive setup.
You can run 100w to each side, and bridge the rear channels to get 700w @ 1 ohm....effectively having a really nice 3 channel amp in a small space.
You can't really go wrong either way though.
Also..pea es:
Don't use the crossovers on the S4a (or 4.150 for that matter) if you want to go active, get a active capable HU or external processing.
i am using the S4 active with a 9887. i am currently experimenting with different drivers on the front stage. space is not really an issue, but the smaller footprint and higher efficiency on the PDX's would be nice. the flexibility of the S4 is nice because i don't need 2 amps for the front stage. the inefficiency on the S4 bothers me tho. passive setups IMO are inefficient too. i was thinking of running the mids off the PDX bridged, but that may be too much headroom. after speaking with another board member who runs similar front drivers with a PDX unbridged, i'm thinking the S4 will be just fine even though it's a bit inefficient. i should be getting the new mid drivers this week. they are 8ohm along with the tweeters. i have a feeling they will sound better than the drivers i have now. we'll see. thanks for the responses. hope to see some more suggestions/opinions...
If you are just looking at a published effecinecy, I run the m1a and s4a on a stock electrical w/ big 3.
One run of 0/1 from battery to a distro block where I split into two runs of 4 ga to the amps. 0/1 grounded to frame.
I don't get any dimming.
Do you already have the S4a?
What drivers do you currently have?
yes i have the S4 already. i run an re12.1 to the sub. no dimming. no big 3. stock electrical. i have the PhassHR series comps(4 ohm mids) which sound really nice with the MX mode on the HU turned to 3. But with the amps i have, i don't see why i need to set the MX mode to anything for it to sound strong. does that make any sense? i do however need to stop being lazy and upgrade to 4ga power. maybe the 4ga power to distro block with 2 8ga is not enough current? the amps read 13.7v at idle.
sorry if my retardedness is obvious and i don't see it.
i also noticed that after i set the gains on the 1/2 channels of the S4 and played some music for a couple days it changed. it read between 11/11.5v after i set it and played music. i set it to 10v the first time, checked it after a few days and it read 11.3v. i thought that was weird. yesterday i set it to 14.1v and haven't checked it yet.
I thought you where supposed to set amps, not volts.
Anything less than 13.5A at the amp is bad, imo if the car is on.
Then he'd have to sell the S4a.
I'm lost here.
He has a 9887, but is running passive. He wants PDX due to smaller footprint, but the S4a allows him to use just run amp, correct?
Why not just go active? In that case you'll still have to add a 2nd amp anyway.
Or am I missing something here?
Right, I am thinking you set the gains by amps, not volts.
Set gains by volts.
Use ohms law. P=R*V^2
So, you know what power you want, you know resistance. Rearrange the equation and you get:
V= square root (P*R).
so, you're ultimately trying to dial in the voltage on the DMM to what you have calculated using that equation.
jblayz1
jblayz1
Miami, FL.
jblayz1
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
