incriminator audio 20.1
depends on your intentions. For a burp, you could prolly run it at 0.5, maybe even 0.25ohm. But daily I wouldn't recommend that
Dude, if you've got the electrical, these will run .5 all day for SURE.
I'm not sure, but I've seen SOME run them @ .25 daily, but they get pretty warm.
Wrong wrong wrong wrong, wrong wrong wrong wrong.
They are stable to 0.35 ohm and a little lower for burps and 0.5 ohm for daily. I ran mine at 0.55 nominal before impedance rise daily for months before I sold it and I never had a single problem with it. They are built like tanks and can go low.
didn't need all those wrongs //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif, but good to know!
Well.. next time don't speak on a topic you apprently know nothing about.. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
you think everyone sets gains correctly and has the electrical system to handle such an amp. I know better. I don't know the original poster, but I know ALOT of equipment abusers. Rather give safe advice. Don't want someone bothering me with messages about how their stuff blew up //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Point understood. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Agreed, someone without sufficient knowledge of the amperage draw at such a low ohm load should not run their amp that low, but the amps run solid below 1 ohm all day. So if the OP has 1/0 wire, knowledge of gain setting, and an extra battery he should be fine.
ghettoknock
ghettoknock
lebanon
brandangd69
Mike Mccabe
Giles
    Jun 27, 2026
